Discuss job on caber flooring,with wet system ufh underneath in the UK Tiling Forum area at TilersForums.com.
deankyall
hi everyone,
had a call tonight to see if i can posibly find time to do a 50m2 floor before end of next week,had a look,its all caber flooring screwed to i assume joists,its ground floor ,new extension,underneath is wet floor ufh ststem,they had marmox thermal boards there,which i said were wrong as the heating is underneath the caber flooring,i suggested ditra,so firstly would you use vs90 or singlepart flex or 2 part flex? to stick ditra down? secondly would the mapei fleece be sufficiant instead,any suggestions would be great as they want it started monday,cheers..
sorry forgot,just porcelain going down
Bubblecraft
Personally, I'd use 2 part flexi mate
Sent from my iPhone using Tapatalk - Couple a' Tools
deankyall
or do you mean overboard with hardie backers first then dietra ,the ufh is underneath the caber flooring so i assume there will be a lot of movement.
Bubblecraft
You CAN tile straight onto Caberfloor whether it's P4 or P5, 18mm or 22mm if you have a height restriction. I'd always sheet where possible but you can if need be with a 2 part flexi & is also suitable for UFH & steel surfaces. As the UFH is under the Caberfloor, you will loose alot of heat putting down Hardibacker or WBP.
DHTiling
Caber floor/chip board is not a suitable product to tile directly to, yes adhesives will stick to it but it is not structurally stable enough to hold tiles in place.
Hardi backer boards will not effect the U-value but marmox types boards can... over lay with hardi backer 250(6mmm) and screw down with screws and use ones that will not be longer than the hardi and caber depth... Use alkaline resistant joint tape on the boards joints and tile with a single part S1 adhesive...
deankyall
thanks dave, this is the route i am suggesting to this customeralso would you deitra this too as its ufh under the caber?,as i said they had thermal boards delivered when i went to price it,so told them it was wrong,trouble is ,after an £80,000 extension they dont have much money( how come its always like that when it comes to finish?) and a novice builder who knows nothing about tiling,so i will tell them and leave it at that,have not got the time to do all this anyway 50m2 with all the board ,mat etc in 2.5 days impossible.
i think ill call nick walker at mepei tomorrow and see what they will spec.
DHTiling
If it was stone tile installation then i would incorporate the likes of Ditra, but with porcelain then if no deflection then Hardi alone will suffice... use adhesive under the boards to take up any undulations in the substrate and then the S1 to adhere the tiles.
deankyall
what would you use under the hardi dave 2 part? its pretty flat.
Reply to job on caber flooring,with wet system ufh underneath in the UK Tiling Forum area at TilersForums.com
