Discuss Is this acceptable work? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi All,
Just moving back in after a bathroom renovation. The tiler has started the grouting though I am not happy with some areas of the work and would appreciate some feedback.
The large tiles corners don't line up, some of the tiles have different thickness grouting. On the image with the shower valve the tiles is raised at one end and the grouting disappears 2/3rds of the way down in the corner.
I assume it won't be an easy fix?
Chris
IMG-20191020-WA0014.jpeg IMG-20191020-WA0012.jpeg IMG-20191020-WA0010.jpeg IMG-20191020-WA0008.jpeg
Dan
Admin
Hi and welcome to the forum. :)
It's okay in some sense. If you're pulling tiles off in the shower area, you're going to affect the tanking. (I assume it HAS had tanking applied somehow? - You need it in shower areas, tiles alone don't 'waterproof' a shower, tanking systems do, either paint-on or other type)
But you could do with getting the tiles how you want them longterm right now. Well before now really but now is better than later when you don't have the same grout mixed up etc. Keep the batch the same.
The grout seems to be sinking. I don't suppose you know what method of fixing has been used? Is it dabs of adhesive in the corners, or a full trowel over the wall and tiles bedded in properly? - They need 100% coverage in shower areas, not 'dot and dab' method where only the corners are fixed. Tiles crack, adhesive wont be strong enough, water ingress is guaranteed, grout sinks (and kind of becomes the only thing holding them on in the end) amongst other things.
I'd like to know a bit more about the tiling I think. Don't suppose you could politely ask the tiler somehow without offending him? At least at this stage. There may be genuine reasons for sinking grout and dodgy tiling around the shower fixings etc for all we know.
Hi Dan
Thanks for the welcome and the reply.
Wedi board was fixed to create a smooth surface and sealed to provide tanking.
I am 99% sure the application was full trowel though will ask carefully when he comes back.
Dan
Admin
Ahhh that's all good then. :)
I'm not sure how he's not managed to the get the tiles flush then with such a smooth surface to tile to! Or why the grout has sunk if there's such a full bed of adhesive behind them.
Might have just mixed the grout too fluid. Or washed off too soon/too much.
Dave
It looks like the grout has been washed off too early before set up and as for the minimal lippage , it could be warped tiles with a tight joint or simply simply not fixed flush enough to adjoining tiles.
Air your concerns with your tiler.
Reply to Is this acceptable work? in the Canada area at TilersForums.com
Apatel
