G
gibsop1
Hi Guys,
New here and new to tiling. Only past experience was a small(ish) tiling project in my kitchen.
I am in the process of doing my bathroom out and have got the the point where I'm seriously thinking about the best way to tile it, and have come up with a few queries.
I've got the tiles 325x450mm ceramic, and will be tiling around bath and a "pipe box" which runs the whole height of the room with 2 external corners.
The Internal corners I'm happy enough with doing, as I understand it; I leave a gap and Silicon the gap, what size gap is recommended between the edge of the tile and face of the other tile?
My more pressing concern is how to finish the external corners. If I go for a corner piece is it just a simple matter of putting it in while I tile, and no need to seal it at all with Silicon?
Since I am not tiling my floor, I'm going to be using some form of "clip together" flooring, do I tile the walls first or lay the floor first?
I know that most of the walls in my flat aren't level/flat obviously there is little I can do about this short of ripping them down, is it safe to use a couple extra mm of adhesive to "pad" the wall out?
I did have a builder/tiler come to give me a quote and one thing he said was that he would double seal the bath - Does this mean sealing the bath to the wall before tiling, then again sealing the tiles to the bath after tiling?
I know some of these are no-brainers but any help is most appreciated 😱)
Paul
Paul
