Insulation Resistance problem with elektra underfloorheating
dannyhull
Hi,
Can anybody help just tried testing 2 brand new coils of elektra underfloor heating cable and got a dead short reading of 0.0 mega ohms between live conductors and a reading of greater than 1000 between live conductors and earth on both cables has anybody had a similar issue or can anybody advise getting no answer from the manufacturer and supply uheat as it is weekend
Hi Dave,
Thank you we have tested between the live conductors at 1000v expecting to see a reading of above 10m ohms and got 0.0 ohms is this normal
What equipment are you using to test the mats......... some of the larger mega testers sometimes have problems reading the ohms of the mat, try using a smaller tester. The reading should be similar to the one stated for that size of mat + or - 10 ohms, they're never exact. If you are still getting a a 0 ohms reading then the mat may be faulty. The tester i use cost me a fiver and i have never had any probs with it. I also use a continuity alarm whilst installing, to make sure I know right away if i damage the mat.
Thanks for the help.
My brotherinlaw is a qualified electrician and he has tested it with a very good tester and he suggests its faulty.
So I thick my best option is to unfortunatly wait until Monday to speak to elektras technical department.
That might be the issue though, seems funny both mats are faulty. Large mega testers often can't read the small amount of ohms that well. A cheaper smaller tester with not such a high capability can often be what's needed.
If you've been posted out two brand new heating mats and BOTH are faulty, I'll eat my hat.
Please do report back tomorrow. :thumbsup:
Do you have a picture of the hat by any chance............... just in case.
Insulation resistance should not be done between live & neutral, you will get a reading of zero because the resistance of the heating cable is low.
Insulation resistance is checked between live+neutral & earth.
Trust this helps.
Thank you eveybody for your help:thumbsup:
Spoke to uheat today very helpful people, told me to test between the live/neutral and earth which as the correct reading so my cables are fine:hurray: I will fit the cable and tiles and let you all know my comments on how the heating performs but so far seems very good and looking forward to warm feet.:cheesy:
Thank god I don't have to eat my hat! It's freezing outside and I've shaved my hair too short as the clipper head fell off!
The hat was one like this one:
I'd give your sparky mate a slap too! (only kidding).
Trust this helps.
Is this just on your heat mats..?
All the ones i have installed, i use my multi meter and check continuity between live and neutral and do an Ohms reading this way as well and i always get the same reading that is on the tag or in the booklet.. never a 0 reading..
That exactly what I do Dave, I have a fluke tester and it always gives me a reading that is the same as the label. Never had to test the earth, varme kits dont have an earth wire.
I'm the same as you Dave....... ohms reading from live and neutral and that's the way the manual tells me too. As for the mat alarm sensor while installing, this is connected to live, neutral and earth.
Not just our mats, all should be checked for insulation resistance - ensures theres no leakage to earth.
What you describe with the multimeter is the resistance check of the mat, which also must be done before and after the install.
As said to Dave, checking with multimeter the resistance is definatley the right thing to do but insulation resistance should also be checked.
If the mat has not earth then it does not comply with the requirements of the 17th edition wiring regulations.
Thanks for that, so in theory this IS the sparks job.. but a test on the mat is sufficient by the tiler..?
dannyhull,
pjrich,
dannyhull,
pjrich,
