Insulation Resistance problem with elektra underfloorheating
dannyhull
Hi,
Can anybody help just tried testing 2 brand new coils of elektra underfloor heating cable and got a dead short reading of 0.0 mega ohms between live conductors and a reading of greater than 1000 between live conductors and earth on both cables has anybody had a similar issue or can anybody advise getting no answer from the manufacturer and supply uheat as it is weekend
Hi Dave,
Thank you we have tested between the live conductors at 1000v expecting to see a reading of above 10m ohms and got 0.0 ohms is this normal
What equipment are you using to test the mats......... some of the larger mega testers sometimes have problems reading the ohms of the mat, try using a smaller tester. The reading should be similar to the one stated for that size of mat + or - 10 ohms, they're never exact. If you are still getting a a 0 ohms reading then the mat may be faulty. The tester i use cost me a fiver and i have never had any probs with it. I also use a continuity alarm whilst installing, to make sure I know right away if i damage the mat.
Thanks for the help.
My brotherinlaw is a qualified electrician and he has tested it with a very good tester and he suggests its faulty.
So I thick my best option is to unfortunatly wait until Monday to speak to elektras technical department.
That might be the issue though, seems funny both mats are faulty. Large mega testers often can't read the small amount of ohms that well. A cheaper smaller tester with not such a high capability can often be what's needed.
If you've been posted out two brand new heating mats and BOTH are faulty, I'll eat my hat.
Please do report back tomorrow. :thumbsup:
dannyhull,
pjrich,
dannyhull,
pjrich,
