How to fix rawl plugs into hard porcelain tiles diamond drill bits 6mm 8mm holesaw
Deleted member 1779
How to drill holes into very hard porcelain tiles for fittings.
So you've done all the hard work and fixed your porcelain tiles. Well done!
Now you need to fix and fit all those fixtures and fittings. A lot of installers run into trouble at this stage if they do not have the right equipment.
To drill 6mm or 8mm holes for rawl plugs you need to use a diamond drill on any hard stone tile like porcelain, granite, marble, travertine and even glass.
Typical example: A loo roll holder !
A loo roll holder still in its box and with fixings
The location of the Loo Roll Holder will be here in the WC...
This is the WC
If you look at the picture above you will see the masking tape on the left. This is where we marked out the wall.
Mark your walls out:
Wall is marked out with masking tape
Prepare the wall by measuring with a spirit level and marking out the tape to get the horizontal line perfect. Then offer up you fitting and mark down so that you have a cross.
To make the first cut into the tile you need your hand electric drill set to slow, the diamond drill bit (we supply) some water and our guide plate.
The drill plate is pushed onto the tile
Place the drill plate over the spot where you want to drill the porcelain tile
Precision placement to within 0.5mm
X marks the spot. And this is where you will make a start to drill the hole.
A small pit is formed.
After a few seconds of drilling a small and perfect pit is begining to form into the tile. Many people are surprised at how neat these holes look. But you must remember the diamond hole saw is a grinder, not a drill! It is taking away only the minimum quantity of your tile. This saves on wear and tear for the drill bit, reduces heat and energy, and most importantly does not break those newly fitted and expensive tiles...
You must now start to add some water.
Adding water via a wet sponge will cool things down...
Do not let the drill tip boil. Add water by holding a small wet sponge UNDER the holesaw. If you draw back the drill bit you can feed water to the working site.
Caution: Drilling for longer than 10 seconds will start to heat the holesaw. Monitor the temperature to prolong its life.
RESULT! A perfect hole with no trauma...
The end result... At the end of three minutes of patient drilling you will be rewarded with a perfect hole!
Fit your rawl plugs and your accessories
Using the right equipment will bring you job satisfaction and your client will be impressed with the results..
TIP: If your client has not yet made up their minds about what to install in their own bathroom you can leave the drills and the guide plate behind for them to finish those last minute things!
All it will cost you is £29.99 for the pack which you can pass on to them.
£29.99 CLICK HERE TO ORDER TODAY!
EVERY JOB HAS FIXTURES & FITTINGS.....
Even if you are not planning to use them straight away this pack is a must for every installers toolbox.
Keep in the van.
Re: How to fix rawl plugs into hard porcelain tiles diamond drill bits 6mm 8mm holesa
Thanks, nice kit, i never do any fixings for towel rails, loo roll holders etc.
Will hopefully see you at Harrogate, to look at some of your larger hole cutters for pipes etc
Aye I noticed that the last time I stayed in Halifax they dont have loo roll holders they like to recycle the newspapers tear a bit of when you need it :lol:
365 your hole saws are the business however I bought the hole saw guide from topps with the suction pad which works great with your saws. Saves having to hold the guide and less chance of slipage :thumbsup:
Gary
Same as, and they have a water connection for the the pressure bottle
Deleted member 1779,
White Room,
White Room,
