how to deal with gap at end of bath
I wouldn't try and fill any gap myself. 2 Options that I can see, move the bath or overboard the wall. I don't see why the plumber shouldn't set the bath properly, he must have seen what was going to happen.
I'd centre the bath and apply a good bead of Silicon. Tile bottom row and build out the bottom of the tile at both ends of the bath. After grouting, apply a neatly finished bead of Silicon.
No F. What I meant is that there is a vertical curve from the top edge of the bath over the end towards the floor. Depending how big the radious is it is likely that even though the tile is over the edge of the bath the top surface of the bath will backfall towards the tiles and hold water.
Thank you easyt - yes, there is a little radius round. I got the cut tiles on today and think I'll get away with a wider than normal bead of Silicon. Fingers crossed.
I know, but beggars and choosers stc. I really would not have any confidence in a 'stretched' Silicon bead. Shame to spoil a brand new job. Can't you get the plumber back?
I used a seal strip when I did bathroom for OH before she moved in. ( 6 yrs ago ?) The one I used looked and worked fine but it went under and behind the bottom row of tiles and was L shape and held firmly down under tension by th etiles.
Yes I agree, I use them occasionally. There is a slimmer type available, whcih is almost flat, it's a sticky back 'L' shape and you can then put a very fine bead of Silicon along the top edge maybe?
The plumber coming back isn't an issue, he's still on site - will be fitting toilet and WHB tomorrow. It's more that I would have to rip out expensive tiles that I have spent time putting up and which would not be salvageable for re-use. If I am still concerned after siliconing I'll get some of the ceramic bath trims that Onlinetiler mentioned, I'd prefer not to have to use them but will if I need to.
Freyanne,
Graham100,
Freyanne,
Graham100,
