Discuss help - power wash marks on limestone in the UK Tiling Forum area at TilersForums.com.
sarah cilliers
Just had grey/black indian limestone slabs laid - the builders gave them a power wash before sealing... but now left with squiqqly lines covering all the stone, and lots of white areas around the grout. I don't they used any product - just water - but obviously they used a concentrated jet. The sealing hasn't been done yet, while we try and figure how how to fix it. Can anything be done?
jay
sounds like something ive seen before high pressure cleaners can do a lot of damage to slate limestone sandstone seem to remove the coloring and the fix relates to the cause if its white now when it dries it may disapear until the sealer goes on i would test seal in a small un seen area 1st :oops:
wetdec
When you use water under pressure on stone the pressure needs applying equally accross the surface.
As the water under pressure hits stone it cuts / fractures particles from the surface which could be compared to etching.
If the water is not applied equally then the effect is different at each stroke EG a close up stroke will cut a deeper trough that one further away. Its this that causes the stone to have marks on it.
It will dry yes but the surface will no longer look the same all over it will appear marked.
This will not apply to slate unless it is dirty or been sealed prior to washing.
:thumbsup:
sarah cilliers
Hi guys - thanks for all your advice.
Good and bad news... builders came back and acid-cleaned the stones to get the power wash lines off, then put one coat of sealer on. It worked on the wiggly lines ... but has still left the cement/grout stains on the edges of some of the tiles. Any advice, before I attack the tiles with steel wool?!
Reply to help - power wash marks on limestone in the UK Tiling Forum area at TilersForums.com
