what do you like to see a thick grout line or a thin grout line on tile work
Discuss grout lines!! in the UK Tiling Forum area at TilersForums.com.
generally speaking if its walls i use a 3mm spacer and if its floors i use a 3mm spacer.
:lol::lol::lol:Originally Posted by brian c
So thats 3mm then Br
This depends upon what type of tile is being used surley..
Tumbled edged will give a thicker line...broken rustic edges can give upto an inch grout lines..like in Bastille limestone..
Then you can have a square rectifed edge..then a thinner grout line is nice..
I just take each job as it comes and use what looks best..
So cannot answer the poll.... as both work..
Reply to grout lines!! in the UK Tiling Forum area at TilersForums.com
