TheRealRobG
I'm planning to tile the floor of a ground floor utility room. It's L-shaped and about 2m along each longest side. One section is inside an alcove and houses the washing machine.
The floor is concrete, and was previously covered with lino, which I removed and scaped off the remaining adhesive.
I then laid a coat of Wickes High Performance self-levelling compound to an average depth of about 7-8mm.
Unfortunately it doesn't seem to have 'levelled' itself as much as I would have liked. The floor wasn't particularly level beforehand. There's a definite linear 'bulge' which runs along the line of the level in this photo, between where the main room meets the alcove:
The SLC seems to have 'rounded off' the ridge somewhat, but there's still quite a difference in level across the room. You can see in the image beloe where there's an 8mm drill holding the level at a level across from the toilet side to the ridge in the middle. Luckily, the floor is pretty level front to back. It's just across its width that I have the problem.
The tiles I'm planning to lay are 10mm thick ceramic 60 x 40 floor tiles (see below). Obviously, being quite large, conforming them to differences in level like this while getting edges butting nicely is quite a challenge.
I guess the question is - should I lay more SLC on top of this to try to even up the level, or will I be OK laying the tiles on a thick bed of flexi adhesive (my preferred brand is Bal).
I'm not too worried about the floor not being perfectly level, but I want to avoid having the tiles come loose or cracking.
Incidentally, if I do need to pour more SLC - do I need to seal the first lot beforehand?
Many thanks.
Many thanks.
