Fitting slate effect tiles to external concrete block wall
R
Rob01
Hi all,
I need to tile a 5-6 block high external wall just need a bit of advice as far as what notched trowel to use etc? addy has come with these rapid set weber.
Thanks alot.
the tile are in a pattern sort of brick work pattern say around 10 little tiles stuck together in a a stagerd pattern which you then put the other 1 next to to match up type thing quite hard to explain.
it looks like each tile has been glued together you can see the marks on the back would you recommened 6-8 mill notched trowel or somthing different?
Rob01,
Rob01,
Rob01,
Rob01,
