Finishing off a ceiling - Do we have too much gap?
You've done the right thing to remove them, although ready mixed is meant for diyers there's no reason you cant do a professional job.
Tubbed addy is water based and dries through the grout lines hence the fact you cannot use it for large tiles as the addy in the middle would never dry.
Any pics as it stands re the cement board?
Tubbed adhesive is a dispersion adhesive, this means to set it has to lose it's moisture and that is through the grout lines as said above and through into the substrate and tile biscuit..
IMO you would be better using a slow set bagged adhesive as this will allow you take up any deviation in the walls as dispersion adhesive should not exceed 3mm depth... and can shrink crack if used deeper.. and will set quicker as it sets hydraulically...
Hey Bob - I'd like to do a decent job and not have tiles popping off all over the place - that's for sure!
They're 25cm x 40cm the dot and dabbed seemed to dry ok. Do you think the all over will dry OK once redone?
Pics of cement boad damage below.
If you do go for bagged adhesive t hen make sure you acrylic prime plaster areas..directions for this will be on the bottle
How was the Aquapanel fixed to the wall, screw only or screws and adhesive?
Not saying you should remove it! just thinking if you can cut out the damaged sections and replace if you have any left over, and tape the joints.
Or you could use the cement based bagged addy to fill the holes and then tank the area over for belt and braces.
The cement board is ok just spread a bit of adhesive in the damaged parts to repair it. As Dave has mentioned above, use a powdered, cement based adhesive, you will get more out of a bag than a tub so is better value and also it's really easy to use (get a slow setting one) and the only difference is you have to mix it yourself. I make it sound simple, and it is really!
Thanks so much for your hep Bob, Dave, Bri.
We'll be hitting the shops first thing in the morning for the bagged adhesive. We WILL have a bathroom!
I personally wouldn't go to Topps Tiles for your adhesive as their retail price on adhesive is eye watering. I'd suggest you go to either a small independant or someone like CTD or Tile Giant. If you find yourself in B&Q then get the 'Buildfix' adhesive rather than unibond or the likes
Sorry to throw more naive questions out there... but I'm reading conflicting stories about how long to leave acrylic primer.
I've bought Buildfix Plaster Primer from B&Q but it doens't list a drying time.
Other acrylic primers seem to have a 1 - 12 hour drying time. Which isn't a great help. I've also ready on one primer that you shouldn't let it dry before tiling over.
Any thoughts? (I'm scared of doing another rubbish job!)
KylieZona,
KylieZona,
KylieZona,
KylieZona,
