tobster11
what do you guys do when you have to cut a tile that buts up to the back (flat side ) of the tile trim due to wall layout i have no option but to do this
or would you peice (one tile) directly above the bath for the tiles to work out without cuts to the trims ,i think that wouldnt look right!!!!
so if you took the first option does the tile sit tight up to the trim with a tiny bit of grout to fill it ,or would you leave a bigger gap?
tia
tia
