Cracked red screed ??
I've been asked to tile what looks like a cracked red screed. It could be some sort of water proof membrane and is about an inch thick which has been laid over the original floor. The building is hundreds of years old. It's mostly solid although it's fair to say that some of it is 'floating' where it's cracked although it's not disintegrating.
My thoughts were to tank the cracks and then over lay with no more ply with flexible addy. Seal the joints and then tile.
The alternative would be to use a decoupling membrane and then tile.
Any thoughts/advice ?
Lewie
Soory mate i have no idea what a red screed is but im looking forward to seeing some of the replies good luck
Just because the building is old dos'nt mean the floor is, was thinking a coat of asphalt for tanking purposes but a picture would help.
Sounds like a red painted screed to me.. [emoji1][emoji1]
When was it laid... Is it old 25 years plus or it is reasonably new... Last 6months?
Based on your description it could be a magnesite screed... Don't see them often these days. If it is it will be red right through (some were green) and they were used up to about 25years ago especially in old council properties. They don't stick to concrete hence they can delaminates and crack. You will find it almost impossible to stick anything cementitious to it and most primers will fail to work as well. Best thing to be done if it is magnesite is break it out and reinstate it with something else.
lewie,
lewie,
lewie,
lewie,
