Discuss Cement Boards in the Canada Tile Advice area at TilersForums.com.
DIYMARK
236
Hertfordshire
I am tiling a cloakroom and small lobby which have a new screed floor. I want perfection, and there are slight imperfections in the level so is there any problem with laying down aqua board? If so, does it require fixing?
Floating is a bit tricky because we there is a gap all around the floor where we have put wide foam strip for expantion (standing upwards) so the mix could leak away down the sides.
I am also battening out around a Geberit WC frame. Should I batten over the top of the frame or stop with battening level with the top?
I am thinking I will tile the top?
White Room
I would'nt be putting aquaboard on a screed floor, could'nt you use a self leveling....
I
Ian
If you're worried about levelling compound running away, use draught excluder or silicone to form a barrier, then remove once the leveller has cured.
White Room
I'd use 6mm hardie glued and screwed but it dos'nt prevent bounce/deflection on the floor...
Reply to Cement Boards in the Canada Tile Advice area at TilersForums.com
