Discuss Cement Boards in the Canada Tile Advice area at TilersForums.com.
I am tiling a cloakroom and small lobby which have a new screed floor. I want perfection, and there are slight imperfections in the level so is there any problem with laying down aqua board? If so, does it require fixing?
Floating is a bit tricky because we there is a gap all around the floor where we have put wide foam strip for expantion (standing upwards) so the mix could leak away down the sides.
I am also battening out around a Geberit WC frame. Should I batten over the top of the frame or stop with battening level with the top?
I am thinking I will tile the top?
Reply to Cement Boards in the Canada Tile Advice area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
