PaulR
Hi
Hi, I'm not a DIY person by any stretch, so I'm looking for some guidance and assistance please
I have a bathroom in an upstairs loft conversion. Its probably 6 months old and contains a square shower cubicle - we moved in 3 months ago. Recently we had some water leakage in the ceiling downstairs and after making holes in the celing and using the shower, we established we have a leak from the shower walls. Its not the tray, nor the seals around the tray, nor the trap and I don't believe it to be the seals around the cubicle or in the corner of the wall where the walls join, as we have done some lengthy tests and the silicone all looks in tact
When we run water at certain points on the shower wall, the leak when looking from below is almost immiedate and comes out of the bottom of the plasterboard as you look up from below.
With some assistance, we have established that the grout in places is no longer solid and the board behind the tiles is plain unskimmed plaster board, with adhisve put straight on to attach some quite large tiles.
I would like some help on what to do next. My insurance company who are only covering the damage, but not the reparation work to sort the shower out, have advised I remove the enclosure, strip the walls back, replace the plasterboard in the shower area with some Aqua panels, simply by cuttting it out and reaffixing with aqua fitments and tape and then re-tiling. Another friend of mine has suggested re-grouting
I am thankfully able to source the same tiles (these are 2 foot by 1 foot) and I wonder if they are too large and heavy. But I also do not have anyone I know who are able to complete all this work. I know a good tiler, but he is not confident of removing the all current tiles cleanly and then replacing the board
Does any one have any advice, any contacts or suggestions of where I could go or who to speak to, to get some
Many thanks - rather depressed by the whole affair
I'm based on the Essex - Herts borders!
