Aqua Dec installation and sub-floor advice
jordelver
Hi,
I'm a newbie DIYer and probably in way over my head. There is no turning back. There may be tears 🙂
I am going to be installing an Aqua Dec in my bathroom. The whole of the floor including (obviously) the Aqua Dec are going to be tiled. Large tiles for most of the floor with smaller (textured) mosaics for the shower area.
The bathroom is currently all timber floorboards - 22mm thick. The Aqua Dec is also 22mm thick, however I'm also going to be installing underfloor heating (Devimat) and I was going to lay an insulation board of some type to a) insulate the floor for the heating, and b) create a nice flat surface to tile onto.
So, by the time I add on the thickness of the insulation board and tiles, either the Aqua Dec is going to have to be made higher, or the rest of the floor lower or else I'm going to be going up a step to get into the bathroom.
Given this, what would be the best course of action? I could remove floorboards, put down ply and an insulation board with the hope I can find those materials in the correct thicknesses. Would that be strong enough?
Thanks for any advice you can give.
Cheers,
Jordan
Thanks for reply Dave. Yeah, I could call them but I don't want to mess them about as I'm planning on doing this myself.
It's not the Aqua Dec I'm worried about (at this point anyway!) it's getting the heights right. There are loads of different products out there and trying to pick the right one can be daunting 🙂 I'm confident I'll be able to put down something new, just wondered what you guys would use?
OK, thanks Dave. Just tried and got:
wetdec has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
:lol:.typical.......leave it with me.......
in the mean time some of the members who have used that tray might be able to help...
i haven't fitted that type so can't comment....:thumbsup:
Hi Jordan, got your pm at last 🙂
Ok from what you say you have :
22mm of chip board existing
An aqua dec wet room former
A Devimat heat pack
As I See It You will Now Have to :
Take up existing floor
Put an insulation between joists at top
Overply your floor with 18/22 mm ply
Cut out for your aquadec
Batten off joists to under board aqua-dec
Fit your aqua-dec
Tape your transitions and corners with a flexible tape
Tank your wall areas
Tile your walls
Fix your gulley collar
Lay a tanking membrane to your floor
Lay Devimat (not over base imo)
Fix floor tiles.
Hows that m8 ??
The Tilers Forums is here to help everyone....... often asking the questions first can prevent the worries later....:yes:
tiler
Better late than never 🙂
A Devimat heat pack
Pretty much, but 22mm standard floorboards rather than chip board.
Sorry, I need a bit of clarification with of some of the terms used 🙂
So, put an insulation board on top of the joists, and then ply on top? Or, just put normal (loft type) insulation between and then ply on top of that?
Fit your aqua-dec
Tile your walls
Fix floor tiles.
Ok, but what do you mean by "Batten off joists to under board aqua-dec" and what's a "gulley collar". Is that to the trap?
Hows that m8 ??
Very much appreciated. Thanks for your time 🙂
Cheers,
Jordan
Just thought of another thing. I forgot to mention that I have bought a 10m2 Impey Tilesafe tanking kit. The wet room shower area floor is approx 1300mm x 1300mm. What should I seal the rest of the room with. I was going to go right up the walls with the Tilesafe within the shower area. What'd reckon?
jordelver,
jordelver,
