Acrylic primer didn't bond to Larsen Tile Adhesive
All Primer, SBR is not ok with all surfaces, for ex. some months ago I have done a job where the builders leveled up the floor with some self leveling compound. Cleaned up the surface, tried it 3 days in a row, on dry and damp surface, applied several coats of Bal primer diluted as recommended by the manufacturer, always let it cure over night, the very next day in some areas where the self leveling compound was more like gypsym dusty kind of looking, the darn primer piled off. So, I would say, never follow the manufacturer advice, do whatever you think is necessary for that particular job. I ended up recleaning the area, damp it with water, mixed the adhesive with SBR and applied the subfloor on top. Achieved a very good bonding. I do believe in the new technology, it just does not always work out as it supposed to. You always have to be a step above and use your common sense.
Some areas of the floor had to be grinded off, the primer would not pill off in those areas. See last picture where the primer penetrated the compound and would not pill off.
I understand what you are trying to say but if you are using a product and the manufacturer advises the best way to use it, my thinking was deviation from the recommended application would void any warranty from the company? In this case it didn't matter as the rep was true to form and weaseled out by taking no responsibility. After a conversation over text with him I quickly realised he'd have difficulty distinguishing between arse and elbow.
Is it a ground floor external wall? Cavity wall or solid wall?
Just wondering if the wall could be damp for the primer to remain tacky. Gypsum plasters shouldn't really be used on solid walls as they act like a sponge and absorb moisture.
I had an issue recently that I've never seen before and any help or advice would be greatly appreciated. I used a Larsen acrylic primer on gyspum walls as instructed on product (walls had been skimmed 8+ weeks previous and moisture tested prior to sealing and tiling). 18 months later and it seems the sealer has not bonded to the wall adhesive. Wall was coated with a 12mm trowel and a standard set flexible adhesive used, the tiles are 900mm by 150mm thin porcelain and within weight limit of plaster. Tiles have now come away from the wall with 100% of adhesive on the tiles and 0% left on the wall with sealer still appearing tacky on the walls. Walls are tiled 1.2m high around the room and the issue is only where sealer was applied to gypsum walls,other walls are scratch coated and solid as should be expected. Usually removal of tiles like these should take plaster and all with it, is this is a sealer failure or am I missing something? Apologies for the long post but I'm in the trade a long time and never encountered this.
Sorry for the late welcome.
Any joy fixing your issues?
Hi trigger, its on an internal wall and was moisture tested before primer was applied. Tiling is only 1.2 meters high on the wall and is painted above if damp was an issue I'd imagine the paint would be showing signs of this.
No Joy, Larsen rep sent through a report blaming everything but their product and claimed that the tile had taken a "weak" layer of gypsum off the wall, I asked how this was possible when trowel marks and sealer can still be seen on the wall and pointed out what he was actually seeing was collapsed adhesive ridges but he didnt want to hear it and said his report was final. Several jobs within my area have failed recently all different tilers all Larsen products and they have not taken responsibility for any of them, I think one of the tile shops have stopped supplying their products because of it. How are their products viewed by tilers in your area Lou?
I'm not a tiler myself but @Dan said they're not one of the most used tile adhesives. We shall start a thread and get some feedback.
Their say isn't final. You can pay The Tile Association a fortune for them to get an 'independent expert' in and do their own report, and if that says it's their adhesive or other product, then you can take them to court and 9/10 the court will go in your favour should the report be in your favour. People have done this a few times on here.
If you want more information, checkout TTA website, that has costs and things on it I think.
Tiler87,
Tiler87,
Tiler87,
Tiler87,
