A-Z of Hand Tools for Tile Fixing | Tiling Tools - Tiling Trowels
Re: A to Z of hand tools
BOX PLANE...Carpenters & Joiners tool.
BREAST DRILL... A portable drill with a plate that is pressed against the chest to force the drill point into the work.
BOXWOOD PLANE/BOXWOOD RULER...Carpenters tools
c
CENTRE PUNCH...Used to punch a point into material,leaving an impression in timber and brickwork to drill,or marks for reference.
CAULKING GUN....A tool for the application of decorators caulk,Silicon and mastics.
CIRCULAR SAW...Great for reducing doors and kitchen plinths.
CIRCLIP-PLIERS...Pliers with a round bar at the end of each jaw that fit in the holes of a circleclip so that it may be sprung open to fit or remove from the workpiece.
CLAW HAMMER..The claw is engineered to withdraw nails from timber or for use as a prise bar.
CRAFT KNIFE...A lightweight utility knife,developed as a heavy duty scalpel used by model makers and the like.
CARBIIDE HOLE SAW.....used to cut holes in cast iron---ceramic tiles---mdf----plasterboard..etc........dave..
CROWBAR, also called a pry bar or prybar, or more informally known as a 'jemmy' or 'jemmy bar' is a [DLMURL="http://en.wikipedia.org/wiki/Tool"]tool[/DLMURL] consisting of a metal bar with a single curved end and flattened points, often with a small fissure on the curved end for removing nails. It is used as a lever to either force apart two objects or to remove nails. Crowbars are commonly used to open nailed wooden boxes. Another common use for larger crowbars is general demolition: for removing nails, prying apart boards, and generally smashing things. It has also been used as a weapon in hold ups.............dave..
CHISEL BITS...used in your sds hammer drill to chase recesses for pipes or cables or using spade chisel to remove tiles etc..........dave..
CLUB HAMMER..ideal accompaniment to the bolster chisel........extra striking force.........dave..
CHOP SAW.... essentially a lightweight circular saw mounted on a spring-loaded pivoting arm, and supported by a metal base. Chop saws are considered the best saw to get very exact, square cuts. Compound miter saws have been developed due to the limited cutting capacity of the chop saw. These are basically chop saws that can make bevel cuts as well as miter cuts.......dave..
GazTech,
GazTech,
