crownford
I have bought some 55 square metres of 400 x 400 tumbled marble tiles, 50% are nero marquina and 50% are carrara white and will be laid throughout our hallway and dining room on top of wet underfloor heating which is covered (in different areas) by two different substrates, ply and cement based screed. To ensure that the rate of expansion differences between the substrates doesn't cause issues we intended to lay a dislocating membrane between the substrates and the tiles.
I provide these details for completeness but the essence of my problem is that I have had two tilers look at the job and both have different ideas as to how to approach it.
The first thinks that the dislocating membrane is unnecessary and that a good flexible adhesive will do the job well enough. He also says that the stone will require sealing with Lithofin stain stop prior to laying to prevent the grout staining or adhering to the tile face. (a real headache when you consider the amount of tiles).
The second thinks that the dislocating membrane is essential and that the tiles should be sealed with the Lithofin only prior to grouting after they are laid.(much easier of course)
Who is right? They both have good experience and both come recommended.
Many thanks in anticipation of your considered response.
