Discuss Preparation in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
LP6767
Preparation
Hi I’m looking to tile my bathroom and I’m just wondering if I can tile straight onto these walls once I scrape off the loose adhesive and plaster or does it need to be rebounded? Also I’m tiling the whole way up do I need to remove the emulsion paint it seems stuck well to the wall and not flaking? I’m going to use Mapei plaster primer before tiling and the tiles I’m using are 600x300 porcelain.
thanks
Paulg83
Preparation
thanks
Best to give the paint a sand and then score all over the top half with a Stanley blade to give a better adhesive bond.
Scrape and make the bottom half flat like the top then prime all walls and use flexible cement based adhesive. Before all the above make sure there's no bounce on your walls. Good luck 👍
LP6767
Thanks mate appreciate the reply
Reply to Preparation in the Canada area at TilersForums.com
Apatel
