Discuss Tile levelling 10cm x 20cm in the Canada Tile Advice area at TilersForums.com.
JS1
I've recently done my first full bathroom tile using 30cm x 60cm tiles and a levelling system which was superb in getting a flat finish with no lippage. I'm doing a second install but with 10cm x 20cm tiles, should I use a levelling system and if so any recommendations on brand? If a levelling system isn't necessary any tips on achieving a no lippage finish gratefully received.
demi34
I don’t think you need the levelling system for small tiles, make sure the walls are straight and flat.
Bopster
Still wouldn't recommend it, you'd get through a serious amount of clips in no time. what substrate are they going into? If it's smooth no clips, if it's rough then correct it
JS1
Thanks all for the replies - helpful and appreciated
[automerge]1603752960[/automerge]
Thanks I propose to use Jackoboard.
cool thanks one wall plaster and one wall aqua panel so nice and smooth
Reply to Tile levelling 10cm x 20cm in the Canada Tile Advice area at TilersForums.com
Teejay
