Discuss Post tiling issues with finish in the Canada Tile Advice area at TilersForums.com.
Will defo be speaking to the Tiler. Just needed to know who to believe and the next steps to take. So thanks for the advice so far.
So is it the cement away or the power clean?
We already have the kf (used diluted then neat) and we have kf intensive cleaner!
You can try the alkaline cleaner mentioned above and if that doesn’t work then you IMO need a stronger cleaner , I once had my son leave residue on black Matt porcelain and what a nightmare it was , only product that worked was acid based.
Let us know how you get on.
It appears you are intent on using a outside only product indoors. IMHO very silly.
If your problem is cement base issue use builders clean Lithofin MN Builders' Clean | Sole UK Agents for Lithofin Products - https://casdron.co.uk/lithofin-mn-builder-s-clean.
If your problem is polymer base problem the I believe power clean is good.
Whichever method you choice to use I hope it goes well and please read the instructions on your chosen product and test in an inconspicuous area first
I'm pretty sure the outdoor cleaner will shift the polymer residue and I'm pretty sure that it wont etch the tiles, but if you do go down that route make sure it's well ventilated and don a respirator.
No Dave, it's outside because it's not safe to use inside, and recommending it for a bathroom with minimal ventilation is wrong, even with no metal in the room which could be damaged. Laughing about it isn't funny. There are plenty of more suitable products out there which would sort the problem and be suitable for internal useThat’s why it’s called outside sealer Doug. Because it needs plenty ventilation 😂.
Reply to Post tiling issues with finish in the Canada Tile Advice area at TilersForums.com
