Discuss Post tiling issues with finish in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Dilalio
Hi all.
Looking for some input and advice.
Recently had master bath tiled and now working on ensuite.
We are the plumbers and have used our Tiler.
Customer not happy with finish of dark grey matt porcelain tiles as they are water marking, have striations and don't have a uniform look when dried.
Supplier is pointing finger at the Tiler and has issued her with wax-off, deep clean and grout removal chemicals (Lithofin). We spent yesterday using the grout remover and while there was some residue which came off, there is still unevenness with the dried finish.
Is the supplier trying to pass off a poor product or are there things we can do to satisfy the customer?
My take, from my experience, is I don't trust the tile.
Any advice greatly appreciated.
Deano.
Dilalio
Everyone is going to ask for photos . . .
Yeah. Lol. I always ask the same on DIYnot.com.
Ill go up and try and capture some now...
[automerge]1570091346[/automerge]
Hope these show the issue.
Bathroom has been used this morning.
Dumbo
Have you got a spare tile that hasn't been used and conducted any water tests our grout cleaner reactions on it .
Dan
Admin
Staff member
Who's done this again?
Grout around the end of the bath instead of cutting the tile to the right shape?
That's not a professional tiler lol
Dave
Staff member
Looks like polymer residue to me , wax off won’t remove it.
You need a stronger product.
Try lithofin cement away to break it down , try on an inconspicuous area first and watch the enamel works.
Dilalio
Thanks for the reply.
What would the polymer residue be from? Is this from the manufacturing process or left over from grouting not being carried out correctly?
We applied this stuff yesterday. Firstly at a 1:10 ratio and then neat (carefully) with plenty of rinsing to keep away from chrome and enamels.
Dave
Staff member
The residue is grout film with polymer residue also within it , it is basically from not washing off early enough and changing water regularly to avoid excessive residue drying on the surface.
If the KF isn’t shifting it then upgrade to cement away , it’s very strong so go careful.
Also you need to use a scotch pad so the slight abrasion from pad helps remove the residue.
Start with diluted product as per instructions and then increase strength till you find a mix ratio that works.
P.s... have a quiet word with your tiler for future jobs 😁
J Sid
Dave, cement away is acid based and is for external use only.
I would try lithofin power clean as my first choice
Reply to Post tiling issues with finish in the Canada area at TilersForums.com
Finias Coroama
