Discuss So forget about cement boards and foam boards and just tile direct onto wood? in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Blunt Tool
CC4765DD-0FE2-4F81-B0D2-A99C79F0E88B.jpeg Link
J Sid
but what room?
have you ever tried getting a builder to seal backs and sides before he fixes them ?
Glynn
The builders will not do much for a tiler, you should know that by now. You would have to take that control yourself, but the priming of the back and side of a ply-board was mainly when the boards were exposed to moisture going onto a groung floor jiosted floor where there was earth below it without a DPM. These floors are becoming less as most new builds are a solid screed and all housing must have a DPM installed.
Time's Ran Out
I assume as tiling onto plywood has been vetoed since this video was shown it no longer applies.
Or is it just wall tiling on to prepared plywood substrate.
Either way I wouldn’t !
Waluigi
Flooring Grade Class 3 ply-wood or Hansons SP 101 ply-wood fixed at 150mm centers, Tilemaster Primeplus, Tilemaster S1 adhesive. Done and guaranteed.
Which thickness ply do you use for testing. I have only ever seen SP101 in 6 and 9mm.
Glynn
Best practice will always be Backer-board first. But the correct ply-board type can still be tiled. BS5385 changed last year. I ask why a substrate that the industry tiled to for twenty years that I know of and probably longer is now now longer suitable? What as changed in 6 months? In my role has technical support we go out to failure on ply-board but mostly they are of the incorrect type and not suitable for tiling from the start. The soft flooring industry use thousands of ply-board sheets every day and pour thousands of gallons of water based smoothing compounds over them and we get zero phone calls with debonding issues. Why can their industry be able to acheive this when the tiling industry acording to BS5385 need to be protected from this "not suitable" substrate. Nobody from BS contacted Tilemaster for our input has to whether Tilemasters adhesives are suitable and have been since Tilemaster developed them, and will continue to be suitable for fixing tiles to suitable ply-boards.
J Sid
yes the BS has changed, why? That question is way above my pay grand.
the hard part from my, a lowly tiler, is getting the builder/chippy/home owner to use and prepare the wooden flooring in a manner so products such as yours can be used. Just will not happen, so much easier to overboard or recommend a flooring other then wood.
Spare Tool
Nice to see a manufacturer stand behind their products and actually give guarantees..
J Sid
and how does an adhesive that can stick a tile to the correct wood flooring type handle the joints in said correct floor?
this is where most failures happen imho
I have to agree with you as I have also seen the failure at floor joint that has had hardie used on it .
Reply to So forget about cement boards and foam boards and just tile direct onto wood? in the Adhesive and Grout area at TilersForums.com
Dawz84
