Discuss So forget about cement boards and foam boards and just tile direct onto wood? in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Flooring Grade Class 3 ply-wood or Hansons SP 101 ply-wood fixed at 150mm centers, Tilemaster Primeplus, Tilemaster S1 adhesive. Done and guaranteed.
Which thickness ply do you use for testing. I have only ever seen SP101 in 6 and 9mm.
I have to agree with you as I have also seen the failure at floor joint that has had hardie used on it .and how does an adhesive that can stick a tile to the correct wood flooring type handle the joints in said correct floor?
this is where most failures happen imho
Reply to So forget about cement boards and foam boards and just tile direct onto wood? in the Adhesive and Grout area at TilersForums.com
