Ohhh you can use spacers with them.. hurrah!!!! Thank youuuuuuIs that because of the thickness of your tiles? Or do you need a 2mm grout joint? If it’s the latter then you can simply add a spacer between tiles.
Discuss Levelling systems & when to use them in the Canada Tile Advice area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Why is it, the stuff you actually need like RIGHT NOW you can never get!! Tile cutter to cut 1200’s.. NOPE! Had to trek to northampton and I can’t bloody use the thing. Flat spacers for levelling. NOPE! Mail order only..
Just pour em into a big plastic tub...looks like your know what your doing then View attachment 102062
Don’t use the clips as spacers use clips thinner than the spacer you use, you can chip the tile when taking them out as I found out a while backOhhh you can use spacers with them.. hurrah!!!! Thank youuuuuu
Oh ok.. I’ll keep that in mind when I’m knocking out the nasty vitrex ones out tomorrowDon’t use the clips as spacers use clips thinner than the spacer you use, you can chip the tile when taking them out as I found out a while back
Honestly the tiles are like concrete! I’ve tried various ways and all have failed. Sigma might actually be coming out to take a sample of the tileI would say yes on a tile that size. If
Why can’t you use cutter?
I left them and started on the other wall tilesHow are you cutting them now.
Wetsaw?Good luck. Hope you work out how to cut
The tiles you are trying to cut are the ones from CTD and I have tiled a wet room lately with the 600x300 tile, they cut no probs at all on my Sigma 3C3M. I do suspect it’s just a case of setting your cutter up right. Have a look online at Sigma there are instructions to set up and cutting/breaking techniquesI left them and started on the other wall tiles
I’ll have a look, cheers mateThe tiles you are trying to cut are the ones from CTD and I have tiled a wet room lately with the 600x300 tile, they cut no probs at all on my Sigma 3C3M. I do suspect it’s just a case of setting your cutter up right. Have a look online at Sigma there are instructions to set up and cutting/breaking techniques
Reply to Levelling systems & when to use them in the Canada Tile Advice area at TilersForums.com
