Levelling systems & when to use them
Is that because of the thickness of your tiles? Or do you need a 2mm grout joint? If it’s the latter then you can simply add a spacer between tiles.
Ohhh you can use spacers with them.. hurrah!!!! Thank youuuuuu
I would say yes on a tile that size. If
Why is it, the stuff you actually need like RIGHT NOW you can never get!! Tile cutter to cut 1200’s.. NOPE! Had to trek to northampton and I can’t bloody use the thing. Flat spacers for levelling. NOPE! Mail order only.. 😡
Why can’t you use cutter?
James De,
James De,
James De,
James De,
