Discuss Wave patten to marry in corners in the Canada Tile Advice area at TilersForums.com.
py rookie
493
torquay,devon
How can you have the wave flow through shower, doesn't marry up the the internal corners
Waluigi
You can- you have to work out every vertical cut before you begin tiling and wrap the tiles round each corner round the entire room
Tile Shop
With difficulty. The only way it can be done is by using both halves of the tile to wrap round the corner. But you may have to compromise the layout on the remainder of the walls to suit. Might need a little bit more time on setting them out and planning the cuts before fixing any more. You may also have to take a hit on the most inconspicuous internal corner not lining up.
Boggs
1,118
Uk
What’s that your tiling on chief?
Boggs
1,118
Uk
Reply to Wave patten to marry in corners in the Canada Tile Advice area at TilersForums.com
  • Poll
