Hanging cabinet on travertine tile and plasterboard - what fixings?
benjchelt
Hi and thanks in advance for any help! I have fitted 12mm thick travertine stone walls on 12.5mm plasterboard with approx 3-4mm adhesive.
There is no way to get to any studs so I am looking at using spring toggle screws into the hollow wall behind. But with the combinations above there will be about 28mm between the cabinet (12kg empty, 4 fittings) and the back of the wall where the spring attaches. The spring toggles I saw suggested a 14mm hole for the spring and 3mm screw, so I am slightly concerned that there is an unsupported 10mm-ish gap horizontally around the screw between the cabinet and the wall.
Does this matter? Or is there a better method? Thanks.
when I use toggle screws I usually screw the toggle itself off the screw and put a grommet (usually home made from plastic or rubber) over the screw so this sits in the hole to support it in the 10mm gap. I have to say though I would be uncomfortable putting 12kg cabinets on small toggle screws. I would tend to use heavier duty fixings specific to the task. Speak to your local kitchen and bathroom suppliers who will be able to help, or put a batten on the wall to span the studs and screw the cabinet fixings into that.
Thanks Alan
I would be tempted to make a hole in the wall behind the cabinet and put timber in even if it is only ply put in the cavity for you to screw into and this would spread the load far more than any cavity fixing.
I've used toggle fixings many times before in circumstances such as these with no issues. Battens in walls are preferable of course.
i'd prefer to use hollow wall anchors rather than toggle fixings. they seem to spread the weight better onto the rear of the plasterboard.
just be sure to flatten the teeth on the head if you use them.
DIY Tiling Forum
benjchelt,
On one,
benjchelt,
On one,
