Discuss What the previous guy did in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
LEH
As you've all been very helpful so far, I thought I'd 'repay' you by sharing a few pics of what the previous owner had done to the bathroom I'm now ripping out...
I know you're all fans of a bit of dot and dab...
Maybe needs a bit more coverage though for fire damaged plasterboard? :D
When I saw signs of backerboard, I thought he had done something right...
And what do you do when you run out of said backerboard?
Brian the Tile
I think the point John is making is that you're relying on what the other person has done, so unless your 'right materials' include a crystal ball then i'd be agreeing with John
Dont think you need a crystal ball to know whether the tiles are good enough to be tiled over common sence should suffice
The thing is, Brian. All you can do is tap them, that doesn’t really tell you anything, they might be stuck with ready mixed onto wall paper
Reply to What the previous guy did in the Canada area at TilersForums.com
mcgtech
