Discuss New here. Some advice in the Canada Tile Advice area at TilersForums.com.
36
Ipswich
Hi all. I'm jason and a diy er. Got to tile a friends kitchen and lounge. Kitchen straight forward concrete floor. The lounge is floor boards nailed to concrete. Can't really backer board it then tile due to height. Can you tile over boards with flexible adhesive as there is no flex in boards and no curling or is it best to rip up boards and tile onto concrete. Any advice would be appreciated. Thanks
Q
Qwerty
Hi Jason. I've moved this thread from the Welcome forum into the Tiling Forum. By all means pop back to the Welcome forum and introduce yourself.
As @pdc says, boards up
36
Ipswich
Thanks for the speedy reply. Boards should be 19mm . Tiles are 12 to 13 mm and 5 to 6mm adhesivery. Will then caulk round edge skirting so should be OK. Should I seal concrete with latex or pvc. Cheers
Pva would be fine with ready mixed adhesive. Where it fails is when gypsum meets pva meets water meets cement and even then it's not a certainty. But when it does go with etringite failure, it really goes!
Reply to New here. Some advice in the Canada Tile Advice area at TilersForums.com
