Discuss Black crust build up in sigma max handle . in the Tile Cutters area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Sometimes when going to use my sigma cutters the handle doesn't run smoothly and on removing it is find there is a black scale build up on the inside of handle . Questions.
Is their something I should be doing to prevent this happening . ( I do spray the bar with silicone spray to clean it but then wipe clean before using it again )
Secondly if this is inevitable what is best way of removing it .
Pardon my ignorance only moved over from the darkside a year ago so am newish to sigma .
Thanks in advance for any help offered
Italy
need anything else?
I Only use wd40 on mine. If some muppet manages to get sawdust everywhere, it can clog up but a blast with a hose and then more wd40 sorts it out.
I Think it's just rubi you can't use solvent on.
Maybe they melt or something?!
I'm same, dub dee on the bar and wipe with a cloth. Remove the handle spray inside and shove some blue roll through it or a cloth to clean and dry it. Biggest issue I had was a burr of metal on the rail which I had to sand off which took some coating off.
L
LM
I take the handle off and use something similar to this below with wd40 dry ptfe lubricant and then dry off with blue roll etc.
Laser Wire Brush 20 Piece Set - http://www.NoLinksToThis/p/laser-wire-brush-20-piece-set/16669?kpid=16669&cm_mmc=Google-_-Product%2520Listing%2520Ads-_-Sales%2520Tracking-_-sales%2520tracking%2520url&gclid=CNiitvHjj9UCFRM8GwodVNgLHA&gclsrc=aw.ds&dclid=CIvc1_Hjj9UCFbgi0wodU6wAQg
Ooh like those . It's also nice to hear that you other guys get same issue and it's not just me and something I'm doing .
Reply to Black crust build up in sigma max handle . in the Tile Cutters area at TilersForums.com
Lowpaul22
