Discuss Floor Levelling small area to tile in the Canada Tile Advice area at TilersForums.com.
Tilerdurden
Using flexi thin set and screws 25mm. As per their own instructions.
So if the boards are screwed down to the subfloor tell me how that acts as an uncoupler? See where I'm going here..? :grimacing: We all have our own methods I will be sticking with mine.
N
Natwasere
You dont screw every inch. There is a certain amount of flex in adhesive plus then board then more adhesive. Whilst you have a point about how much it decouples it by I'm still saying if it's already boarded why would you mat it also? Do you board and mat most timber floors? I highly doubt that. It's one or the other usually and which one you choose is irrelevant.
Tilerdurden
Depends on area being tiled. If it's wet areas I'll board and mat regardless of material type. If it's tongue and groove dry area it'll get both. Dry area I'll use mat with chipboard.
Reply to Floor Levelling small area to tile in the Canada Tile Advice area at TilersForums.com
  • Poll
