Discuss Grinder Blade for Mitre Tiles - How to mitre tiles using a grinder - freehand mitred tiles in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Just realised, i dont have a veri speed grinder, mines 12000rps
Bosch GWS 7-115E 115mm Variable Speed Angle Grinder 230v 0601388203 | Buy Sigma Simple Bevel Machine 36A3 Online from Pro Tiler Tools - http://www.*******************/sigma-simple-bevel-machine-36a3/47565/bosch-gws-7-115e-115mm-variable-speed-angle-grinder-230v-0601388203
dynamictiling
568
glasgow
I found the wet cutter quite good. Interesting to hear other people's thoughts on it. Might try the variable grinder and buffing pad next time.
dynamictiling
568
glasgow
Was a nightmare to do, least helped by the fact the window was a country mile off of the level. Remember putting my level on the actual window and my bead ended up sitting back in the van lol. Black grout contributed to the never ending nightmare.
Usual joiners that the customer has used (and they are dead good!) **** it! Tiler can catch it...
20170323_142944.jpg 20170323_134247.jpg 20170323_134222.jpg 20170321_142210.jpg
dynamictiling
568
glasgow
Ohhh the customer's spark had the shaver socket sitting tight against wall! If I tiled it the cover plate wouldn't have fitted! Magic, maybe the tiler can cut 10mm off of the chrome cover to make it fit.
I despise when the customer provides their 'own' tradesmen! Anyhow rant over.
Ttt1601
628
Abbotts Ann, Hampshire
I don't use a variable speed grinder (might do now with the price of that Bosch tho) I just hand work the Tile usually with a 200 grit pad or a wet stone then cut the back out with a turbo blade from right lines, very similar to as turbo I believe, just keeping a sponge on the blade as @3_fall does, works a treat for me
J Sid
spoke to my tool suppliers today to see if than can beat that price. Did some ring about to Bosch UK and got told it's not something they sell in this country and must be an import.
Reply to Grinder Blade for Mitre Tiles - How to mitre tiles using a grinder - freehand mitred tiles in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
