Discuss Tilers spirit levels?? in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Italy
Are you asking me Antonio?
then, in summary.
you say, that the receiver is not needed, because you see the line. (as I understand it).
ok, even I can see the line, but the distance is long, how do you know if you're at 60cm from the wall ?. you get up and go to see if the line is 60 cm ?, put to the table with the viewfinder? or you have a cat's sight ?. ;)
or, as I start to think, that I use the laser for other things. while you use it for other things.
I use the laser to seek the setting, before starting work. few times use the laser to control the alignment of the tiles.
when I found the quadrature of the floor, mark with pencil the two most distant points, I take the knock colored thread and pull a line.
lay a straight edge on the line and start laying.
this is the last time I speak of the receiver, otherwise we retire talking about the receiver. ;)
ps. when you test the receiver on the floor, you will remember of antonio. ahah
Spare Tool
I'm still not following.
In my defence, i'm not the sharpest tool in the box:)
Set the receiver up say 50 cm from a wall, set laser up 50cm from the other end of the room, saves traipsing up n down the room to measure your line off the wall, the PLS comes with targets that can be used in the same way...school day H ;)
Italy
technically, the receiver, does not serve it for radio and not even for the smartphone.
its function is other ;)
Reply to Tilers spirit levels?? in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
Lowpaul22
