Discuss Which way do you do it? in the Canada Tile Advice area at TilersForums.com.
Rick-o
518
Guernsey C.I
Hi all,
Was talking with an adhesive rep yesterday and he was demonstrating some slc.. his demo was over decoupling membrane which raised the question.. Do you level over the decoupling membrane or under it?
If you had under tile heating for example would you put this on the levelled (wood lets say) floor then mat over or would you mat the floor then cable and level?
Rick
By the way he said either is acceptable!!
Tile Shop
wood substrate - insulation boards - wires - slc - decoupling - adhesive - tiles
an additional Decoupling membrane shouldn't be required as the coated insulation boards have decoupling properties, but also if they are fitted correctly, any movement will be absolutely minimal.
But if you wanted to go belts and braces it would do no harm, but i've always been advised that the decoup always goes over the slc. For instance with ditra, the adhesive doesn't stick to it, but anchors into it so that the matting is free to stretch without transferring the stress. SLC may work the same way but speak to the manufacturer before doing it.
Rick-o
518
Guernsey C.I
I am with you Paul, I have (at least for the last few years) put the membrane on last. I do tend to use it as I know a couple of tilers that have had floors fail just using 6mm board, which apparently was glued and screwed??
The leveller was ardex (any of them but this was arditex Na) and it was onto ditra matting.
J Sid
really surprised an Ardex rep would consider doing this with there close relationship with Schluter.
Rick-o
518
Guernsey C.I
Yeah I was too Julian as I had seen Schluter recommended ditra being directly under the tile.. He did say Schluter recommend that way due to the ease of getting tiles up but they were happy which ever way it was done.. To me I would go with what schluter say but wondered what other peoples opinions were!
H
hmtiling
No, it weakens a bit. Reliant on the bond between the slc and adhesive.
You can do it that way - at least that what they said last time I was there!
No, the mechanical bond between the ADHESIVE and ditra is lost impish if it's been slc'd
Reply to Which way do you do it? in the Canada Tile Advice area at TilersForums.com
