Discuss Floor self levelling compound in the Tile Adhesive / Grout Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
custard powder in water.... oh hang on... thats non newtonian.....
Casper
Have decided to use the Mapei Ultraplan renovation screed sold at Screwfix but cannot find any information on whether the cement floor screed has to be primed first. If so would BAL SBR primer be suitable as I have some left over after tiling.
Casper
One last silly question (hopefully). The levelling compound must be spread a minimum thickness of 2mm but how do you know the thickness you have put down. I thought of fixing something 2mm thick onto the highest part of the floor and ensure that this just gets covered with the mix.
Spare Tool
2mm spacer on your high point, come off that with a 400 level n stick however many 2 mil spacers together to give you your depths
L
LM
Casper another similar method is to insert screws at say 600mm intervals into the floor coming of the your desired finished substrate height using a level and simply fill the leveller up to the top of the screw heads which will all be level with each other, just avoid pipes!
Spare Tool
SnC sub Lee
peteablard
1,058
Cheshire
if you were thinking of laying vinyl I'd personally go for a 2 part like Ardex NA. You get a much smoother finish than a water based fibre re enforced one
Reply to Floor self levelling compound in the Tile Adhesive / Grout Advice area at TilersForums.com
