Discuss New Tiled Floor Problem, Advice Please? in the Canada Tile Advice area at TilersForums.com.
H
hmtiling
There are a multiple of things that can make grout patchy like the majority of the grout in your pics are,
Poor quality grout
Joints that aren't properly cleaned out before grouting which leads to different depths hence different shades Too much water either by unevenly mixed batches
Too much water left on different parts of the floor after poor washing off
Efflorescence can even form if the grouting was done in an area where a cold channel of air is blowing through, say at doorways etc because the grout stays wet too long in those areas which then dries slower in those specific areas, the slower it dries the lighter it will be
As for the extremely dark patch in the pic it looks like something has been spilt on the joint and stained it, if there was a leaking pipe its more likely that the 'wet' looking patch would be more over the floor in general and it would certainly be growing in size
that's what i meant to say ;)
MW Smith Ceramics
As lee Mac says above!.....also could be trapped moisture coming from the screed if the floor was tiled too soon and the builders didn't use a hygrometer but then you would have effloressence coming through the joint too which doesn't seem to be showing up......I think there is a problem with the application/method of grouting on this one, looks as tho they havnt got the mix ratio correct and washed off too wet and too much before allowing the grout to dry.......I would look at using a product called LTP grout stain remover using an LTP Clawbrush to scrub the grout joints, try 50/50 ratio with water around the joints of 1 tile let it react then scrub then clean with plenty of water and see how that comes up, it should bring the grout up to original colour and uniformed when dry......use neat and do the same thing if that doesn't work......you can purchase these items from the website as follows.....www.ltp-online.co.uk
Send over some pics when you have carried this out......
Hope it helps
MW Smith Ceramics
Hope it helps
Oh forgot to mention if you do use this stuff wear gloves as it is acidic!.......also it will strip any surface sealer that has been applied, if this happens ( you will see if it has ) then use LTP MPG SEALER to reseal with polished porcelain but you may be okay if the porcelains has been wax sealed by the manufacturer but you will see
It around the edges of the tile if this happens......
MW Smith Ceramics
Oh I see there not polished so no need to worry about strippingcany sealer.......okay well give the LTP grout stain remover a go and don't forget to order the LTP xlawbrush its s god send.......order it online or if you have a tile giant in the area you can purchase both items from there ......this really should sort your problem out if it is just patchy grout which it looks like.....
SJPurdy
I think the edges of the patches are to well defined to be damp coming from underneath or drying of the grout patchiness. I would guess it is something spilled (eg. oil, grease, paint thinner, flux) and then wiped up. If this is the case and it is just on the surface then it may be removable using a suitable cleaner (but which one?); if it has soaked into the grout then the section of grout will need to be taken out and then re-grouted.
Lets not over complicate things here jeez.
Ask them to some and re grout the dark patches and see how it goes. It will probably fix your problem. You didn't mention generally patchy grout so I assume you don't want the whole lot re grouting.
It looks like some dirt or other on the grout that's all, there has probably been all sorts of trades walking all over it after its been tiled
moomarine
You found this a lot easier than I did to explain! This is exactly what I meant! (I think)
moomarine
Iv just had a look round our kitchen at home as I was sure we had stains like this and they are definitely from dropped fluids as this floor was done just before we moved in and I can remember some of the spills that happened. Also strong cleaning products can cause it when mopping etc. Probably a cheap grout used as well.
Reply to New Tiled Floor Problem, Advice Please? in the Canada Tile Advice area at TilersForums.com
