Discuss Ensuite Updates in the DIY Tiling Forum area at TilersForums.com.
scotmk
Thanks, it took a day just to set out, I had the shower tray , shower seat, bath lip, 2 windows (which I had to end up cutting out the top to make it work). To get over. The gap at the top was the best I could get after all options were weighed out. it was bigger, so I ended up putting another sheet of backer board on the top facing bath/seat area to raise it another 5mm.
I will grout all the top, mask it then run some white paint (same as ceiling) to make it fall into the ceiling and make it vanish that way, worked ok in my last bathroom
scotmk
All my base cabinets have been fitted today and I have inserted my digital control for the bath and basin, looking great.
scotmk
I am very impressed with the Taptile Control, works really well.
www.taptilecontrols.com
Just got the sticker kn for the moment. Got 2 options, use the etching kit that they do which is some kinda acid that eats away a few mm of the tile (using a template lieut he sticker) then those get filled with the grout. Or I found some really thin 2mm chrome round mosaic tiles which I may position on top. But got to test the acid on a spare tile as they are not glazed so don't know if that will work.
Reply to Ensuite Updates in the DIY Tiling Forum area at TilersForums.com
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
  • Question
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
