Tiling On A Sloping Wall/ceiling
I have a shower to tile in a loft conversion - it has plumb walls to half way and then the walls follow the pitch of the roof for the remainder.
I am planning to use Weber.set SPF and their primer PR360 - it's going on backer boards and the tiles are 100 x 300's ceramics.
Does that sound ok? never tiled on a slope before.
Like this?
It should be fine with ceramics
No different to tiling the top of a window reveal.
I always spread the adhesive on the substrate and the tile to ensure a good bond..
Yes, I agree with the above, no surprise there then 😉
The problem I normally fine is the intersection between wall and slope, nearly always not straight or level, be prepared to do a bit of prep
@Andy Allen
I take it Andy u've not tiled that area before?
The slopey bit? Haha I think it's called a mansard, not 100% tho.
When u have a full height tile on main wall and a tile sloping inward like that at an angle, the distance between the bottom left of the wall tile and the top of tile on the mansard, is greater than the height of a full tile.
Therefore the top of the mansard tile falls short of the wall tile.
Clear as mud? Haha
If you're still confused (I know I am!) I'll do a diagram to explain it. 🙂
@Andy Allen
Clear as mud? Haha
You've lost me lol.
Ignoring the angled boxing in completely I know none of that will line up its the top cut above the window looks smaller than the top cut on the right hand wall ..
You've lost me lol.
Ahhhhh! Why didn't u say so! Hehe
Don't go away, gimme 10 and I'll show u why! 🙂
Two-Trowels,
pink,
Two-Trowels,
pink,
