Well could write a list D, how long u got? Hahaha
Discuss Advice On The Finer Detail Please in the Tanking and Wetrooms area at TilersForums.com.
Some manufacturers state not to use silicone around the gulley,Seal around the grid with grout or silicone? Grout I would have thought?
definitely not silicone. not ever. sub-tile water cannot drain if you silicone around the gully.Some manufacturers state not to use silicone around the gulley,
you could argue that in using epoxy you'll be waterproofing the whole thing anyway, but if you really trust that then why waterproof the substrates? the main reason is that silicone tends to completely fill the area around the drain collar. most manufacturers won't entertain any claims if silicones been used. then again, do they ever?!Not even if you used epoxy grout on the former?
Reply to Advice On The Finer Detail Please in the Tanking and Wetrooms area at TilersForums.com
