So,what's the new layout going to be like Geoff. .
What have you got on then @Dave ?
9 balconies on new asphalt in quarries!
Access from roof only, down to terrace!
5 stories up, ladder from roof to terrace not wide enough to get my shoulders down, have to turn sideways.
Ladder comes down in the centre of two terraces, so left and right terrace to tile.
Drainage point in far opposite corners from ladder in middle.
And why are they being tiled when they have new asphalt down?
Simple! They fall the wrong way and don't drain properly!
So I gotta fix it!
Gimme strength!!!
So I'm working backwards from drain to ladder and I've got to increase fall as I go backwards!
Swapsies anyone? Haha
Prime with tilemaster primeplus slurry and tilemaster ultimate adhesive.
Is the asphalt exterior though? The oils in it are an issue.
I'm with @3_fall on this one.....
http://www.tilemasteradhesives.co.uk/docs/uploads/PrimePlus_TDS_2014.pdf
Could be worth a call to the tech guys but I've never known it to be an issue. If anything, new asphalt will be better than old as no or little oils leached out
Check and double check , everyday is a learning day on tilersforums 🙂
Not a problem you with 3_fall but if it is exterior grade beware warranty. Webber won't guarantee it.
Haha yeah I know mate no worries!
Yeah I've seen that by weber
I'm waiting on reply from architect, he's aware now, as am I!
And I'll be speaking with Tilemaster also.
As I said earlier, thank you for your question.
Might have saved me some grief!
Finishing a wet room tmoz dave then onto the next two got some nice pics might have some nice pics for jotm
