Currently reading:
Crackle Glaze tile discoloured
Discuss Crackle Glaze tile discoloured in the Australia Tiling Forum area at TilersForums.com.
dodd4721
Shower.jpg I work as a self employed tiler and after moving in to my new home decided to re fit the bathroom and install a shower tray and frameless enclosure. I purchased 6 square metres of antique smooth crackle glaze tiles from Walls & Floors.co.uk and used them for the two walls of the shower enclosure. The tiles were sealed twice with LTP crackle glaze sealer before use and instructions were followed exactly. The tiles were applied to fully tanked and sealed shower walls using Mapei adhesive, the shower wall profile brackets were fitted to fully tiled and grouted walls as per the manufacturers fitting installation procedure.The wall grout used was Mapei Kerapoxy epoxy grout.
The corner tiles in both corners of the bottom row of the shower enclosure have changed colour completely from cream to a uniform and even mid putty grey, in addition the edges of some of the other tiles have developed a grey edge to them also, when the tiles were fitted they were not discoloured in any way and the problem has developed after 2 weeks of use.
The thought of having to strip out all of the tiles and starting again is too much to bear, can anyone offer any advice or does anyone know of this happening before? I'm hoping that it may be a case of letting the tiles dry out and resealing but I fear this may not be the case?
Any help or advice would be very much appreciated.
Sean Kelly
1,068
Ruislip
I've just looked at the Walls & Floors website and although it does not say anything about where you can and can't put these tiles it does however show a picture of the tiles with a toothbrush and cup!!
Other crackle glazed tiles have this bit of info: However, in areas where water is directly hitting the tile, such as in a shower, we strongly recommend in addition applying LTP Grout and Tile Protector after fixing, which will add extra protection.
Some tile manufacturers recommend soaking the tiles in sealer for 5 mins prior to fixing!
Personally I would not use crackle glazed tiles in a shower area.
I came to the help of a man in Chiswick a couple of years ago when his tiles were letting in water. I had to seal them about 6 times to cure the problem. However, these tiles will need to be re sealed probably every year.
Maybe water has got into your tiles and a period of no use of the shower will return the tile back to its colour. Remember that tanking will add to the drying time of adhesive.
I can't offer any real solutions to your issue, but i'm sure that you will get a few more replies soon.
Good luck.
dodd4721
Thanks Sean, your advice is much appreciated, when you sealed your customer's tiles in Chiswick what sealer did you use? - the LTP Grout & Tile Protector or a different branded product? I'm hoping the tiles have dried out in a week or so, there is a heated towel rail in the bathroom that's permanently on.
I've resisted the thought of speeding things up with a hair dryer on a gentle setting as I don't want to trap any mould in the glaze although as they have only been laid for 2 weeks there is no mould yet in the glaze itself anyway, only in the very edges of the grout lines [although the grout used was Mapei Kerapoxy which is not supposed to go mouldy?] I can only think this black mould is the residual moisture escaping from the biscuit of the tile. The Shower Wall Profile brackets were fitted to fully tiled and grouted walsl and silicone sealed on both vertical sides, I have checked the area directly underneath the shower tray and there are no leaks at all. I can only think the moisture is coming in through the face of the tile via the crackle glaze, everywhere else is perfectly fitted and sealed.
dodd4721
Hi David, I have got pics but I can't figure out how to put them on this thread. I will try to suss it out and post some as soon as I do, I've checked for leaks from the enclosure but everything is water tight, it can only be coming in through the face of the tile. When I cut the tiles I remember thinking how thin and fragile the glaze seemed, too late now I realise but if there is a way of saving them I will be most relieved! Based on my own experience I would now not recommend crackle glaze tiles to anyone tiling a shower enclosure.
It does seem to be biscuit wetting from showering.
got any pics ?
Sean Kelly
1,068
Ruislip
It's strange that only full tiles are affected (according to photo).
Did you use a wet cutter for the bottom row?
These tiles do absorb a lot of water. If they are sealed whilst they still contain water then the water will be trapped within the tile.
When they are being sealed you will probably hear a 'cracking noise'. This is the glaze on the tile still crackling. I would seal again and again.
As you have now found out, these tiles are not really suited to a shower environment. I personally would not guarantee my work if I installed in a shower. Some customers are very insistent, like the ones that have slippery polished porcelain in their bathrooms!
As an experiment measure out some water and pour it over a tile in a dish. See how much water the tile absorbs.
How long did you leave the tiles before you sealed?
I would suggest you also contact Walls & Floors, but I have dealt with them in the past and they are not experts in tiles or anything tile related.
Reply to Crackle Glaze tile discoloured in the Australia Tiling Forum area at TilersForums.com
  • Sticky
