Discuss 1880 house with lime render. in the Australia Tiling Forum area at TilersForums.com.
sifly
36
Hi, I am replacing a bathroom and after removing the old tiles have found old lime /horsehair render on brick. This seems pretty solid and wondered if I can tile over with 250 mm x8mm tiles after priming /stabilizing wall?
Or do I rip it off and render with sand/cement?... There will be a shower above the bath.
Cheers Si.
sifly
36
I see the 6mm boards are mainly listed as for floors, would it be OK if screwed directly onto the render, or should I go 12? I don't have space for wood battens.
I'll make a decision later after I remove the tiles above the bath and see how well they are fixed.
Cheers Si.
Ps. Just hope the neighbours don't mind the hammer drill!
Reply to 1880 house with lime render. in the Australia Tiling Forum area at TilersForums.com
