mike1979
I use spax 25 mm but we aren't going to have a row over screws are we
I use spax 25 mm but we aren't going to have a row over screws are we![]()
Maybe your driver/bit could be the problem. Recently I changed over to use an impact driver,but forgot it one day and asked to use a joiners 18v DeWalt cordless......with the right driver and the right bit it would pull the screws all the way thru the HardieWhat size of turbo gold or spax would you use for hardie? I found that 3.5 mm x 25mm a too weak and don't pull board strong enough to the plywood, where is original hardie screws pull very tight
The plasterboard gives when shear stress is applied where plywood and hardie don't ,under stress drywall screws snap very easily but if you wish to use them then go for it
