Discuss Expansion joints between rooms in the Canada Tile Advice area at TilersForums.com.
K
Katie279
Hi all,
just a quick one - am planning to tile four rooms on the ground floor with the same tiles and hopefully create a nice flow between the rooms of tiles.
am using flexible adhesive and grout and have planned to leave a 0.6mm expansion gap around the edges of the rooms. I've seen various expansion joint trims for across rooms, should is use one between each room?
just a thought!
boards, marmox, UFH, SLC, 600x600 Porcelain?
Yes. Expansion joints needed in the doorways at least. More info needed re sizes etc for where joints may be needed.
Ajax123
Hi all,
just a thought!
0.6mm expansion round the edges.... Good luck measuring that ;)
K
Katie279
Cheers guys - heh, yes sorry am a bit anal like that, my day job is an electronic engineer designing euro fighter, missile systems etc, so we often measure in hundredths of a millimetre, so this is totally relaxed by my day standards!
On the upside, I've certainly got the tools to measure to that accuracy quite easily! ;)
K
Katie279
Hi Carl,
thanks for the pitch! ;) like to see companies interacting with their customers communities.
On that basis, I'll make a special point of buying schluter expansion joints, however need them tomorrow - do you know anywhere that sells these in Scotland? Am near Kinross.
otherwise does anyone know any alternatives from the usual places (have got a tile giant in Perth)
The Legend; Phil Hobson RIP
I work until it's right.:lol::thumbsup:
Diggy
Priced a schluter 20mm expansion joint the other week , nearly choked on me cornflakes ,
£60 odd quid for a 2.5m length.:yikes:
Diggy
K
Katie279
Ouch! Cant seem to find any around me - any other alternatives? It'll be going from tiled room to the next tiled room.
Ps don't worry half mill phil, had a friend called three inch Pete - can assure you he was far more embarrassed... ;)
:lol::lol::lol:
DHTiling
6mm min for perimeter joints and changes in direction to tiling like L shaped rooms should be movement jointed at the L transition.. other wise areas of over say a max of 40 mtrs should be bayed .. this would be say an example of a room 8 x 5 mtrs squared.. other wise joint at door ways as said above.
Reply to Expansion joints between rooms in the Canada Tile Advice area at TilersForums.com
Lowpaul22
