Discuss Raimondi levelling pegs tested on a recent job in the Canada Tile Advice area at TilersForums.com.
Jeff the tiler
Hey all. I said I would post my experience using Raimondi floor levelling pegs. Got a complete set from Kwik splt what i thought would do the job for a 34 metre floor using 60 x 30 porcelain tiles, so 500 3mm base clips and 200 wedges. I would say the cost was was around the £80 mark. Sounds expensive but purchased with a Pull rapid washboy and a few other bits and so got some discount which helped.
So new pliers boxes of clips and wedges and away I went.
Initially broke a few clips by not getting the pressure correct on the pliers and some of the clips seemed to snap of their own accord which was not great.
Then over time i got the feel of the pressure and how many clicks [3 generally]you could push the wedge into the clip [serated top edge of the wedge clicks as you push it into the clip] I started to really see the benefit of the system. I lifted a couple of tiles to check if it was creating air gaps but it seemed fine. An important point is the clips are there to make slight adjustment in height so you stil have to get the tile pretty level first. if you try to pull up to much
difference the clips will break as the suction of adhesive creates to much pressure.
I would say the main benefit was that over the 34 metres I did not have to lift a tile to re bed and over the the whole job would say I saved a good few hours in time making sure everyhting was perfectly flat and level. So just in man hours I would say they paid for themselves. I know some will be reading this saying i can get a perfectly flat floor without these but honestly, and i am not promoting Raimondi as there are others out there, they certainly help me do the job quicker than by the traditinal method of eye, straight edge and spirit level.
I am old school and quite reluctant to change but this is a product i will definately use again on domestic price work even if i can not pass on the cost just in man hours saved it covers the cost.
I am trying them on 60 x 60 next week and, also have some Australian Atr levelling pegs so hopefully will be able to post a thread comparing them next week.
If you have any questions let me know and i will try to answer if I can
R
rainsco
hallo, i saw the raimondi video and i thought to myself on a small format its a lot of work to install it and to get rid of it and sort the white from the red ones.
so can you tell me how long do you take for the floor (alone?) and what kind of screed was it?
i never saw the result live but if the screed is not ultraflat and one tile ist to deep and you push the tiles with force there must be spots without adhesive? i can imagine but i think in future, about 20 years or something when we do some renovations it would be special to find a floor without using plastik? i hope this system isn´t as easy to install and get a perfekt surface like click parquet.
Jeff the tiler
Hey, Glasgow tiler I have been able to try on a small area where I needed to build up by 25mm or so, the clips were fine but I agree they are not for everyone, on large commercial work completely impractical on a financial basis.
One thing to add I have been able to use the wedges three times over so far but I think that probably about it with them as the serrated top edges are showing wear now.
Again I would like to stress so far only tried on porcelain so can not give a view on other tiles i.e travertine etc.
For me the pegs are not there to level the floor they lessen the chance of lippage when the adhesive is drying back. The clips will not pull a tile up or down by huge amounts so the adhesive contact should not be broken as the clips will break if you squeeze the wedge in with to much force
jonnyc
i am a bit lost on why these clips are needed for stone
we have had instances where porcelain flexes and can see the point in this instance possibly although with care we can avoid lippage.
stone does not flex in same way and can only think that if you applied these clips on a stone that does not flex then you are a causing other stesses and possibly forcing the tile off the bed laid.
Andy Tiler
1,043
manchester
Hi johny, I didn't really need the clips on this job, but I chose to use them!
They don't cause any stress they just hold the tile in place while the adhesive goes off, once the wedge is removed it's only the adhesive holding them down.
Hope this helps ;)
Andy Tiler
1,043
manchester
I have always been taught to read the floor/wall substrates before tiling with straight/feather edge etc.. and prep before if required, surely we can serrate a floor/wall and fix tiles without lippage . Personally i don't think its for me at this moment in time.
I also levelled that floor Houston it was out by 25/30 mm in places.these systems still require a certain amount of skill to use.!! ;)
charlie1
Be interesting to test this system on a typical flor where people would be tempted to use it... lets say a slightly uneven floor with +/-5mm over a 1.8 edge, then lay a line if tiles and activate the system, lets see how the adhesive deforme under the tiles and where it goes! Having given this matter thought, that the system seems to do is turn all the tiles in to one large tile the size of the room so ask yourself this totally hypothetical question, what trowel size would you use on a typical floor with a tile the size of your room??? 20+mm ?? ... who knows... something hs to give somewhere, there has to be a downside to achieving these perfect results on the surface!
Andy Tiler
1,043
manchester
Hi Charlie, I wouldn't advise anybody tonus
Andy Tiler
1,043
manchester
Ignore that last post Charlie lol. Was gonna write summat but I've done to much typing tonight... ;)
R
rainsco
last year i got an call for bit for an architect own house. all floors with 180x80cm tiles with half shifted layout. on walls 120 x 60 (4mm) over 150m² . a very high end house. raimondi or other leveling system was required and part of the agreement.
that was one of the causes (not the main) i didn´t enter. i have no problem with the size of the tiles but no expierence with the system and this was no job to try it out.
what i want to say. this was no DIY Job.
the architect has his cause why he claims the system.
but in my opinion time is no advantage of these systems. when i watch the videos i think in time when you install the plastik you can take the tile up and set adhesive on right place and level it twice and then you have perfect bed and perfect surface.
Andy Tiler
1,043
manchester
Looking at this system you need four clips ,I think the ATR system looks as if its a bit quicker as you only use one on the four corners will not try it yet but will wait to read if any other tilers have used them still think they are a bit pricey.
The ATR system is a good system aswell IMO!! But takes a bit of getting used to..!
glasgow_tiler
they just seem like they could be a pain to use and in a way pointless, but i can see were they could be helpfull to some folks
P
Phil22
Hi Jeff, sorry if you've already posted this, but where did you get the ATR system from in uk?, I've looked but can only see on places like ebay and ebid from the usa?
cheers
Reply to Raimondi levelling pegs tested on a recent job in the Canada Tile Advice area at TilersForums.com
