Mapei Grout Scratches
Has anybody out there had an issue with Mapei Ultrcolour Plus Grout scratching the surface of ceramic tiles?
Just fixed a small area of high gloss black ceramics and grouted as usual using Mapei Anthracite grout. When I polished of the minimal residue almost all of the tiles had fine surface scratches, only really visible when the lights directly above them were turned on. I checked each tile before fixing and they were fine so it is obviously the grouting that has done it. I have fixed loads of the same tile but this is the first time I've used Anthracite grout on them, on floors yes but a first on walls and on gloss black.
Anyone had the same?
Anyone any possible remedies apart from taking them all off and starting again but with a different grout?
Spooner
First time (and last) that I've used that type of grout with glossy tiles, the client got it along with the tiles. Like I said, I've not had a problem with any other grout like this. Not the end of the world, a couple of hours to knock them off and start again. Nice coffee and cake makes it worth a revisit.
On sensitive surfaces try using kera colour FF.
Hm, interesting, does that mean it's a finer grout than ultracolour then? Could be interesting for me ... does it come in the same colour range? Just googled it and it mentions fugolastic - have you ever used that, does that make it creamier still?
Wide joint grouts are a coarse grain of sand.. so yes the finer the grout the better for glass or polished surfaces.. FF will go to a 6mm joint.
And same colour pallet as Ultra colour
I must admit I've been using a different Ultra brand lately, supplies of anything are very limited in Scarborough, but will look into that one, thanks.. 🙂 what about the fugolastic, is that the kind of effect as SBR Bond?
you need to remember to use a brand new clean grout float too, I have seen metal trim scratched where old groat floats were used
spooner68,
Alonzo,
spooner68,
Alonzo,
